- May 27, 2016
- 3,477
Getting a copper entirely around the inductor, but in a way that avoids a shorted turn, will stop any antenna-type E-Field. I have done this using a ground plane under all of a small PSU circuit, and bringing the metal shield sides up from it, but when completing the "box" over the top, I used two "lids", one folded over the top of the other, but with a thin sticky tape between them. The remaining two ends got the same treatment. In appearance, it was a untidy homemade bodge-up, but it made a Faraday "cage". The overlapping sufaces with sticky tape between them completed the Faraday cage by the capacitance acting as an AC short-circuit. It's very difficult for the field trapped in the thin dielectric between two coppers that are DC shorted together, to make any external electric near field to affect anything, much less to start any real farfield EM propagation.
Alternating magnetic near-fields cannot escape a truly shorted Faraday cage (shorted turn effect), but they can escape far and wide if the cage is not truly shorted, like the inductor shield I describe. The magnetic near field can inductively couple to traces, and add in their noise. Fascinating (to me) is how they can still get a true RF propagation going, including generating a new electric far-field. The electric near-field component may be trapped in the shield overlap, but the magnetic component can still get out and make a true RF radiation happen. That is how direction-finding shielded Goniometer's, and communication magloops work as antennas.
At the dimensions of the PCB, it's all so close in terms of wavelengths that only near-fields can be coupling this noise into the traces. Moving the entire switcher away, and having a a piece of mu-metal, and maybe some ferrite in the design of the sense head assembly, should approach having the noise reduce to only that of thermal, diode, and amplifier front-end that we already know about.
I have to agree. It is simply obvious that the solution to switcher noise is to move it away, and filter the noise. For the purposes of your experiment, it may be faster and easier just to use a battery or two hooked up. You know the final circuit will have the PSU live elsewhere (and be a clean one) anyway!
Thanks for the seasonal wishes, and likewise for yourself.
