OK - we are agreed that a transparent" shield can be aluminium.
Underneath the sensor will be lead. Pretty much the entire little volume will have a liner of lead.
The "measurement cell" will also have mu-metal. Mu-Metal, as a metal box, schieves electrostatic screening as well.
Concerning the mounting structure of the Am241 sources.
I had planned a gadget looking shaped a bit like a flashlight from the days of D cells with a open end that one puts up against the metal to be tested. If the metal sample is small enough, it gets put down over it, onto a small sheet of lead.
My first CAD modelling of it sucked. I started again. I hoped to mount 6 or 8 sources in small drilled recesses arranged around a circular lead tube, all pointing at an angle onto the "hot zone". The holes just deep enough so as not to waste radiation, but masking it from making to the sensor. In the centre of all that is the tube with the sensor up it, again arranged to collect the maximum of what pings upwards, but shadowed from what comes out the sources.
I thought the sources could be put into their settings, about 5mm deep, down onto a dab of epoxy.
It is a bit of a fiddle to get at them.
_ _
The ion chamber covers them up. They are facing "upward" away from the board. You eventually get down to a mounting disc that is itself peened into a contact ring. Maybe the arrangement differs depending on where you got them from.
_ _
I had thought the most suitable would be the approx 5mm diameter peened disc which has the approx 2mm diameter metal-looking thing that is presumably some alloy with Am241 thrown in. That means losing the contact ring with connect solder tab.
I think I can cut the outer peening with the little die grinder diamond wheel, and pop the middle disc out. That would be compact enough to set around the radiation zone target region. We have quite a lot of lattitude to use a wide angle. The photons won't reflect off anything, and they definitely can't go around corners.
The sensor would be set on it's own little PCB, which is attached at right angles to the electronics PCB. At the rear, the LVDS network type cable goes off to the little computer. The region of PCB nearest the data cable take-off has an initially unpopulated section to mount a PIC or something to turn the cable into USB. There may be some case to make it USB from the outset.
Local circumstances make it awkward to do the experiment here right now, so I am hoping someone can tell me what the deal is in attempting to make an approximately 2" end of a Am241 ray gun assembly .. out of lead!
Another question comes to mind. Other than as a calibration source, is the stuff in Thorium mantles useful as a source?
I have to check what is the Thorium activity, to see if it includes gamma.
For the present then, back to A/D conversion.
_ _
_ _
