Hydrogen is up there! Think acetylene is worse, but haven't checked flammability limits in a while.I thought hydrogen was the most bang-a-licious
Sent from my SM-S911U using Tapatalk
Hydrogen and helium and maybe another gas, have Joule Thompson coefficients that are negative at our "normal" temperatures. So unlike oxygen or nitrogen or argon, expanding room temperature hydrogen will heat up instead of cooling. This presents problems if you want to make liquid helium or hydrogen. However, if you can cool the compressed gas below some magic temperature, then the JT coefficient becomes positive again. So the compressed hydrogen needs to be cooled below that magic temperature. If expanded at that temperature, it will then cool further.OK- What are the physics of hydrogen heating on expansion?
That makes it safer, I believe. I had also heard that the inside of an acetylene tank contains balsawood, but I haven't ever opened one to find out. Think it's used to prevent the acetone from sloshing around.Yes acetylene can decompose with heat or shock and it is exothermic so I can cause chain reaction and explosion. I believe that is why is it stored by dissolving in acetone in the tanks?
