- Dec 18, 2019
- 7,196
Smaller SMT parts have lower parasitic capacitance but are harder to manipulate.A couple of notes, one regarding the PCB design. One application note I found suggested putting a ground trace underneath the TIA feedback resistor, to shunt-out some of the parasitic capacitance that's across the resistor. This is meant to improve the circuit bandwidth. There wasn't enough room to do that between the 0805 SMT resistor pads so I placed traces on the two inner layers. I _could_ go to a larger resistor like a 1206 but they have higher parasitic capacitance anyway. And there's nothing that can be done regarding parasitic capacitance across the top of the resistor, anyway. The feedback resistor is R5 on the layout. A thru-hole resistor that has a wrap of thin wire around its middle would _really_ knock down that parasitic capacitance, but do I actually want to go there??
The second note is that I found a surprisingly inexpensive flow sensor whose range matches the low flow rates I'd want for a continuous-flow gas proportional counter. It could be used to make a relatively cheap mass flow controller in the 0-30 SCCM range. Digikey has them for $45 but unfortunately they drop-ship directly from the German manufacturer so shipping is a bit high. I also have been looking into DIY flow sensors that use cheap NTC thermistors. Thing is, I'd still need a "real" flow sensor to calibrate the home-made one.
Since I have a ball flow meter for my TIG, I'd be tempted to use it for something like this. However, the scale is different for different gases, since their properties differ, at least for argon and helium. Absolute calibration is hard, but is it necessary for the application? Is it possible to discover the "window" experimentally? How wide is the window of operation? I'd think if it could operate for a minute or two statically, then there's some window width.
