- Dec 18, 2019
- 7,760
I have 17.0.36.0 now. Installing wine by itself showed some ntlm_auth issues. Eventually I installed winbind, which should have fixed that.My LTSpice is LTspice XVII(x64) version (17.0.35.0)
When I first downloaded it as .exe I think, linux Mint automatically popped up and gave me the choice to have the Wine install happen.
When updates are ready, LTSpice just brings the pop-up to let one do the update.
It may be that before you do anything with LTSPIce updates, you do the update for Pop!OS
The download should complete. I am not sure what is happening there.
The text file attached in post #1231 has a bunch of YouTube links, which is where I learned the basic ways this can work.
One can actually drop an entire model file into the circuit drawing as a "comment", and have the simulation use it, because it ends up in the netlist.
This is yuk! It takes up lots of space, and clutters everything.
The exact same result can be had with .inc to "include" it, as if it was in the drawing.
Then, the way to make using it easy, is to use it as a .lib file.
I did not make the .lib SPICE directive directly. I started with a .inc include.
The .lib statement got made automatically when I clicked on the correct button choice.
I am suspicious of the update not completing. It may be better to get your previous designs stashed somewhere, and delete all trace .of LTSpice, and load up again. This means losing the c_drive in wine, and then also removing the LTSpice folder in /hjome/bruce/Documents. That said, I am wary, because that seems unnecessary if you can already make an old filter simulate.
So I think the wine install of LTspice did not go smoothly. However, I'm not sure how to uninstall LTspice - even after saving all my old sim files. How does one break the symlink without messing other stuff up?
