Another possibility for positioning the sources might be to 3d print the complex shape and use lead inserts. For a single use one could print the punch(es) to press the lead into the complex piece.
3D-Printed?
That you suggest this makes me think you might have access to a 3D-printer.
Looking back to post
#530 on page 53, there is a whole bunch of geometry and pictures. For convenience, I put one of them here again.
This would be machined entirely out of lead, like Mr Pete has shown can be done.
Alternatively, using lead bucket inserts, and the rest is out of aluminium or 3D-printed plastic
Now suppose I enlarge the holes to accept a lead bucket pressed or glued into them.
If the "walls" are 1.6mm thick, then 99% X-rays are stopped.
If the walls are 1.8mm thick, then it's 99.9%
If the walls are 2mm thick, then go with more "9s"
Now suppose I add the models of the lead source shielding mugs, and also, alter the body to have a lead shield cylinder stuck in there around the PIN diode. The rest of the body now becomes aluminium or 3D-printed plastic. There is still to be a aluminium barrier foil or disc behind the plastic (not shown), and come to that, possibly also aluminium foil or graphite over the aperture to the PIN diode.
However this goes together, all those low noise electronics are in a Faraday enclosure, also with some effort to design against magnetic field ingress.
Now suppose you get a STEP file of the shape, or the FreeCAD model. I have not yet tried generating G-Code, or suchlike.
(Is that only for CNC machining)? There may be strategies, like printing first a thin base layer to have it stick down to the platform, and "supports".
Whatever it be, if you have a re-worked model STEP, or CAD from FreeCAD, do you have a printer to make one?
For
@RJSakowski , Hi there. We have today been looking at your posts.
With the geometry I had in mind, there is not any path for source photons to hit anything except the test target. Photons may travel to the end of the universe, but they can't go around corners! The original geometry could do with some improving, but..
If the 3D-printing route is taken, one has the advantage that just about any shape can be made, and
@WobblyHand might want to try.
For those without 3D printers ,to make the holes in a turned metal blank, one needs a rotary or index-able something under the drill. It may be that a much simpler shape, with all the sources facing forward, not tipped at any angle, would work just as well. I think Mark
@homebrewed has already shown that it seems to work OK
I am at present enmeshed in electronics, and giving consideration to switched gain range amplifiers, but if the STEP file is desired, I can try modifications to the CAD model now.
