Needing more than a spark test?
This explains some of my thinking. My apologies, there is a lot here.
Op-Amps
I am back and getting technical amid all sorts of decisions in getting my circuit together. The critical op-amps used in the transimpedance front-end are decided, as are the ADC drivers. My ADC has differential input, and needs the interface to single ended operation.
Gain distribution and noise.
I opted to have the first TIA gain resistance not be 1M, nor any of the "higher" values I have seen in TIA circuits. Instead, it is at a value where it's noise contribution is below that of the amplifier input. There is not much point in having a amplifier capable of seeing down to the PIN diode noise floor, then throwing that advantage away with a spectacular, bandwidth-limiting TIA one-stage gain. Anything above about 36dB there puts the noise figure safe from any subsequent circuitry, and relaxes the noise specification for op-amps we might use.
Thus, after the first TIA stage follows one or two op-amps to get to the final gain, and correct signal polarity.
Hardware triggers removed
To keep things simple, and reduce components, I have opted to not include window comparator trigger, which would use up a dual IC. Triggers can be done better in software.
Hardware peak detect removed
Similarly, I have removed the peak-detect -> peak hold. I am sure it does a great job, but for the same reasons as trigger, having the sampled pulses captured means the peak is quite available in software, without quite tricky high bandwidth hardware, each with a price!
50Hz / 60Hz Notch Filter
This is something I do include in the design. It is easy enough to leave out, replaced by a link. There are a whole bunch of different types, from expensive "programmable" state-variable filters. Twin-T with 2 opamps, Fliege topology, Bainter Notch, etc.
The well-known Twin-T with the two-op-amps simulated using the same LT1807 as for the ADC driver giving a -48dB notch. Throwing in two sets of passives resistors and capacitors, aimed at making 50Hz and 60Hz notches all in one go removed a band from 49.5Hz to 61Hz to -56dB, with a hump at 55Hz at about -48dB. The notches themselves were at -64dB for 50Hz, and -72dB for 60Hz.
I don't know how this actually works! The dedicated single-frequency 60Hz hum remover by itself does not do as well. It simulates at -50dB.
We learn how much the actual performance of these much depends on tolerance and balancing of critical components, and how some circuits are much more tolerant. Simulated performance showing notches 70dB to 100dB deep are more likely to achieve 50dB to 60dB in practice.
I have found notch filters implemented with a couple of old-school bipolar transistors that seem to have spectacular performance!
OnefFilter package - regardless
I am much tempted by the Twin-T, regardless it has six passives that need to be really good. Some others are also tempting, but need three or four op-amps. Whichever we use, the filter takes one physical package, a dual, or a quad. It does not have to have a special low noise, but does need a gain-bandwidth product good enough to deliver 300kHz undistorted. That would mean 20MHz minimum. The LT1807's are there just because I have them around. For a 4-op-amp package, I thought maybe ADA4891-4ARUZ-R7. It's not pennies at £3.56 for one IC with 4 opamps in it.
If anyone has a suggestion for your favourite affordable op-amps in dual or quad small-outline SMD that are up to delivering deep notch filters while still having acceptable gain of at least x1 over the bandwidth we need for the rest of the pulse signal, then here is the place to say what is your favourite. Pin-outs for 14 and 16-pin packs tend to be standard. It may be one can throw in whatever is to hand at the time.
The sketch
I include here a scrappy little sketch which may help @rwm to imagine what's there. I left a lot out, like the special lengths we go to regulated supplies, and prevent overloading anything. Sorry, but right now is not when I want to be producing drawing package documentation.
The (simple) arrangement
Start with the PIN diode, which has 3 x lithium button cells for bias, fed through a high value current limiting resistor with it's noise shunted by capacitor. I drew a lot from the TIA circuits of Glen Brisebois (Linear Technology) contributions from 2001 through 2022. Going back to the two basic ways we operate these PIN diodes, most circuits seen operate in photovoltaic mode at zero bias, and not at X-ray wavelengths. Photons arrive, and make volts, just like the solar panel on your roof!
We, instead, bias the large area diode OFF with 10V, and so we create a depleted layer that won't conduct, and it has a much reduced capacitance for it's (huge) area. Photons arrive in that insulating layer, and make electrons that will get gathered up by the bias field, and so we get a pulse.
The DC isolation capacitor
This would normally be a thing that loses us control of where the "bottom" of the pulse is. No more DC reference! In theory, the signal should float to where the pulse average is - except this one does not! The capacitor is optimum, fully big enough to deliver all the energy in the capacitance of the PIN diode in one quick pulse, without affecting it's amplitude. In simulation, I did not see the base line drift up. Here we are dealing with between 80pA and about 5nA. It seemed to work! Losing the 10V bias lets us use the very low noise TIA front end circuits.
First stage gain choice
As explained before, and drawing my earlier times having to fish a clean signal from some feeble satellite, the gain has to be enough to ensure that only the signal, and the noise of molecules banging about in the first stage are what gets amplified. If enough gain, the noise will be so huge as to make any subsequent stages noise contributions become trivial. Of course, the signal got amplified as well. The S/N signal/noise ratio is preserved. To this end, the TIA gain resistor is chosen not be be so large as to mess it up.
A 1Meg resistor is 130nV/√Hz, and if we want 300KHz bandwidth to nicely preserve the wave-shape of a 13uS pulse, then it makes 71uV, which is a darn racket compared to the 4.3nV/√Hz input of out op-amp, making only 2.3uV. I will be experimenting with that resistor, going for a value some 10's of K, and possibly using one of the feedback TIA networks explained by Jerald Graeme, and used by Hammamatsu Corp.
There is also the option of the FET input, also from Brisebois.
What's with the extra FET?
This is an optional variation to the TIA circuit. The FET and one op-amp work together, with the other op-amp in the pack used to force the bias at the FET to be zero. This can also be done without the FET.
So what is there?
In practice, this first stage is a LTC6268, which is a single lonely op-amp in a 8-pin SO pqackage. This is to have enough spacing between the input pins to allow a guard ring track. At it's simplest option, that is the only amplifier there. The feedback resistor is put in as two in series, to limit the stray capacitance across, and the stability compensation (a few pF) is contrived by having two SMD capacitors in series.
There is some minor tracking to allow using any of the "Feedback Tee" circuits from the traditional wisdom TIA book. These are just tracking options, not having components on unless you want to play.
If a FET input stage is chosen (simulated so far as best), then one has to drag in another op-amp, which needs to be low noise, but not necessarily as wideband as the LTC6268. There are a few resistors and capacitors that go with these active parts.
The rest of the gain
In my circuit, this is provided by two stages. They might be the op-amps in just one package. The input noise requirement is no longer there, but they need to be fast enough, and work within the 2.5V. First is a necessary polarity reversal, plus a huge chunk of gain. The next part has logic switched analogue gain range settings controlled from the little computer. This gain feature need not be there. Just ignore it and settle for one resistor if you like, or leave out the whole op-amp, although it will still be there in the package. Analogue switches can be ADG1201BRJZ or LTC202CS#PBF. The first is SPDT -NO (single pole double throw - normally open) or the latter is Quad SPST (single pole single throw). I have not tried it yet.
The 60Hz interference noise rejection filter
This is explained elsewhere earlier in this post. I see it as something we should have. I am just not sure where it should go. Should it be where I have shown it, or should it be immediately after the TIA? I will take suggestions on this point.
The ADC driver.
Most ADCs need a good driver, and this one takes it's supply from the ADC chip itself. If one has a ready-made single ended signal, and an ADC that does not care, then just leave it out. Alternatively, it can drive both the ADCs @homebrewed and I have been discussing. At this point, I was implementing from the circuits shown in the datasheet.
The KiCad circuit
This is still evolving. It seems everything I want is often just not available, or if taken from a supply site, comes locked up with all sorts of other software marketing lock-in tools. I have to "edit" the models to get what I want, without their add-ons. I end up making a lot of my own symbols. When I have it, and am getting down to tracking, I will post it. Folk here may have a opinion on whether we should exchange complete stuff via PM. If I have any PCBs over, even partially assembled, I am OK to distribute them between us.
Another option that a bit more public but would avoid further loading up an (ostensibly) machining-centric forum, would be to create a group on groups.io or Google groups to exchange information. Post a link to it, maybe in a new topic rather than somewhere in the current tome.
Groups.io might charge a fee these days but I suspect Google Groups has a free version. There's github as well but I'm not so familiar with it, other than as a source for code I'm interested in. Not sure how well suited it is for a lot of messaging.
Just throwing some thoughts out there.
I hold that everything about this is ultimately all about machining interest, all the way from it's original motivation, to what what we would do with it. Figuring out what alloy, or is it weldable, or how tough to machine, or will it corrode, or what heat treatment, whatever. It is supposed to be useful. The mechanical bits are going to take some machine work to make it come together. This includes how to make parts out of lead, which should prove interesting. We are not making an electronics interest Elecktor type project! This stuff includes radioactive nuclear bits, stolen out of smoke detectors, which I think is one one of the coolest aspects. :)
I get that, for sure. But handling the S/W and H/W combination in a manageable way surely requires something more suited for that purpose. And if something happens to any of the primary contributors, the IP, such as it is, has a lower chance of parts of it being lost.
OK - I get that. I have backed up space, and I am sure so do you. There is even "the cloud", though I have never used it, nor stuff like Google Drive.
I could put a repository on my server, and I own a .net domain, but I am sure things should be recoverable enough if we just send it to each other.
Still, you have got me thinking about it. My recent experience reminds me that things can happen, and suddenly all the good stuff, CAD models, simulations, circuits, PCB designs, software source code, etc. can go "poof".
I will go along with whatever you folks think is good.
Graham- Thank you for your detailed post. Of course I had to read it multiple times and follow along on the diagram! but it it super helpful to get me generally familiar with the issues. Not having a strong electronics background some of this is over my head but a lot is readily understandable. Seems like this will be a very complex circuit when you get all the support electronics in place. That AD7622 for example.
Yes, all the careful design is pretty complex, and when we invoke high tech ADC stuff, and the damn clever software, this takes it far into quality design area. It's all still prototyping, and there are still lots of opportunities to hit a stumble. The final outcome will belie all this, leaving it looking small, and very boring simple, pretty much masking what went into the design. Keeping the component count small, yet allowing spend on quality components in the critical places where we have to, is the aim.
Note: Regarding the AD7622. Take a look back at post #961 on Page 97 --> HERE
Without needing to understand any of the detail, notice how much it is like the AD7667 that Mark is using, to the extent one can use the same board tracking.
I added the stuff in blue, and the differences in red, but in practice, it's a tiny little square thing 7mm x 7mm, taking up 9mm x 9mm when you include the pins. It will not look like much, but hopefully, it will perform like a champ!
  • Like
Reactions: rwm
A LTSpice Simulation Tip
For those who use circuit simulation, and need a bit of confidence, and like to have the results in a few seconds.
For a lot of my circuits, I have to pay attention to be getting something that I am reasonably confident is also going to happen in reality, without taking a age.
Wave pulse shapes
The first mess-ups came when trying to generate a good version of a photon current pulse. I would go to Control Panel and mess with ..
"Absolute Voltage Tolerance" 1e-005, and I might start messing with the -005, taking it to -006, or -007.
Similarly, and to better effect, I would change the current tolerance.
"Absolute Current Tolerance" 1e-009. I would take it to 5e-012
These settings are not remembered between program startups. Very strange, but in the end, I managed to get away with not needing to do this. I could make a nice shaped pulse, but I am not sure what changed.
Convergence - it seems to run forever
- no, it need not!
I made the happy discovery that one need not run for ages hoping the stepping will converge. Pretty much every time, it is mindlessly repeating the same useless iteration with Gmin set to some small value like 8e-007, and doing "fill-ins" This is it's first try in adaptive source stepping, and it can get hung up there.
Ignore it - just press ESC.
It will move on to N-R (Newton-Raphson) iterations.
My active stuff gets hung up there as well, so press ESC again.
What happens next is blinding fast, and I am not sure how it ends up in Pseudo-Transient analysis, but you won't know, because it completes too fast. All you see is the calculation has stopped, and putting the probe on what you want to display has the answer right there!
One command fixes it!
Force the thing with a .OPTIONS directive. All three commands at once, and then turn pTranTau to ON with a "1".
.options GminSteps=0, SrcSteps=0, pTranTau=1
Great! I won't get too nerdy curious about exactly why. It just works! All that seems to happen is my four op-amps circuit state-variable filter, with it's two integrators in it, and all associated components, seems to complete in a second or so, with exactly the same plot as one gets if you leave it for ages. :)
I have added a rudimentary MCA capability to my Teensy XRF setup, and I almost immediately discovered a problem that needs to addressed.
First, here's a photo showing the "spectrum" acquired with _no_ sample present, but the Am241 smoke detector capsule assembly (an aluminum cup to hold the sources, glued to a 1/16" thick shield) is:
And here is a photo taken when the Am241 sources were removed:
These results are telling me a couple of things. First, it appears that I'm seeing some energy discrimination, as shown in the first photo. Second, it's clear that some "stuff" from the Am241 is getting through my lead shield arrangement. I need to revisit the geometry and shielding design. But, the setup _is_ a prototype so it's shown I still have some "larnin" to do.
Finally, I present a spectrum acquired with the Am241 sources AND a steel sample present:
I can't say that the steel spectrum looks much different compared to photo #1, but the count statistics are lower for the steel sample (and the iron signal probably is swamped out by the junk coming directly from the Am241). The "maxcounts" value shown on the display is the largest value in the MCA array, not the number of counts accumulated overall. My plotting routine autoscales the data so the maximum count always is drawn at Yscreen = 239.
No smoothing was performed on the MCA data, it's plotted in the same form as acquired.
Time to find all that lead sheeting I bought awhile back....
