- Nov 14, 2016
- 3,344
See this post above: https://www.hobby-machinist.com/threads/need-more-tool-holders.96008/page-3#post-895965
And then this post (right below): https://www.hobby-machinist.com/threads/need-more-tool-holders.96008/post-895969
The issue is the "H" height as illustrated in the Shars diagram. As demonstrated above, the tool tip of the 1/2'' tool in AXA holder will stick out above the center line unless I grind down the tool tips to lower them. It will still work, and I may use some of them - I have about 4 planks I could grind down if I need it. The 3/8'' HSS tools should fit without any fuss and that pleases me because most of my tools I have are in that size anyway.
I just got some 1/2" tool bits in a box of used lathe tooling, I'll load one up and see if I can make it fit without going through a bunch of hoops. Issue with the OXA would be I don't think 1/2" will be fully supported by the holder so you may be in a pickle either way.
