I have a Tormach and a lot of TTS tooling. It's good in the 1-2hp range and is inexpensive. Beyond that you need taper tooling. ER20 holders are most common and the "standard" for all the reasons rwm said above. You can also buy bulk TTS holders from eBay or AliExpress cheap in er20. I have some thoughts personally about set screw holders being slightly more rigid and slightly shorter than ER20 in my most common end mills size which is 5/16. Remember... 1hp. I do not have pull out issues with any of them.
Based on what is available today I would go with a lot of ER20 TTS holders for all end mills down to 1/8. Then a few ER16 which are also still out there cheap for 1/8, 1/16 and 1/32.
Er32 in as-needed one offs only for specific large tooling you cant mount any other way like a shell mill... TTS is not great for high rigidity with big tooling so you won't have many of these. Mostly for surface finishing, light passes.
