- Dec 18, 2022
- 2,688
That looks like silver solder, not brazing and if your joining Aluminum that is what it is, the Mapp and LP gas torches will work for that and all you have to remember is put the heat to your work piece and let it melt the filler and draw it into the area to be joined.Well today I brazed 1/8 to 1/8 6061 with just a blue bottle and got a strong bond- can't break it with a hammer, Not pretty yet but strong as hell. Also I expect to braze 5/16 SS bolt to .065 SS tube and was told blue bottle would work fine but not as fast as oxy-acet. I'll know a lot more in a few days
Soldering, in particular silver solder is good and will form a good joint but you need to be aware it is weaker than a brazed joint which is a welded joint. Solder is like gluing, there isn't any penetration into the base metal, you are depending on the surface bond. Brazing will use a filler material which is similar to the material being joined (I have used metal clothes hangers to join mild steels) and require you to heat the pieces to be joined to a cherry red and the filler to the same and you melt the filler and base metal together to form the joint (penetration between the 2).
Be aware, soldering Aluminum requires the black paste flux I think.... Its been a while.....
