That's good.
You want a solid foundation.
I don't know how much my old 13" South Bend weighs but it is a beast. The Bridgeport is no slouch either.
I can't imagine moving one of those big old Cincinnati or Tucker & Kearney (SP)? machines.
Enjoy that lathe.
I'm enjoying this lathe. I had to shim the cutting tool using pieces of hacksaw blades and strips from a coke can.
No button in the center of the round stock and a piece of hacksaw blade stays vertical when pressing it between the workpiece and the cutting tool.
I got some chatter which went away by taking shallower facing cuts.
I also tried turning down the diameter of the round stock with the lead screw engaged. No chatter but the finish was not too good.
Speed was 1000 rpm (carbide insert). Calculating the speed for 30 mm. diameter round stock and HSS tools gave me 300 rpm but the recommended speed for carbide is supposed to be 2 to 3 times that. I'll experiment with different speeds though.
This is my very first attempt at using a lathe and the tool didn't crash into the chuck jaws, nor did the carbide insert shatter.
BTW those chips are hot and judging from the color they were at around 200 to 250 deg. C.
