Monarch 10EE - what to do?
I'm going to be fabricating end covers for the machine. Besides the covers being missing, the tag for the backgear lever is also missing. Can someone out there be kind enough to scan or photocopy one 1:1 scale for me? I can then have it replicated via 3D printing and paint it so it looks original. Here is a picture of what I'm looking to replicate
Oh...and one other item. Does anyone out there have a 2 V-belt spindle pulley that they are willing to part with? I know they come in different sizes. My machine is supposed to be a 4000 RPM machine.
Do you have a good photo looking into the top of your apron? I curious to see if both of the feed clutch oil lines are in place.
Phayb, you will have to calculate the diameter of the pulley based on the existing pulley - then you can ask if someone has one near the same size, or you can order one, they aren't expensive - just tedious to find... What part of Canada are you at? anywhere near Alberta?
Nope. Just north of Toronto, Ontario
Some progress. Headstock is back together an on the bed once again.
I had to refurbish the feed gears by grinding the hubs down a bit to clean them up and fitting bronze bushings into the holders. That seemed to work out pretty good. One of the other fellas on this forum, vettebob, did a similar repair.
I also refurbished the dial face on the tachometer by printing a new one. I chose the closest font I had available on my CAD program when I drew it up and it turned out ok once it was printed out. I checked the tachometer calibration and it seems to be working pretty good. We'll see how accurate it is when I finally get the machine under power.
Next job is a clean up and refurb of the gearbox. All of the internals look to be ok so I'm not sure I need to tear into it too far...just a really good solvent wash out.
Found one.
