- Dec 20, 2012
- 9,408
I would use more speed for both. With harder steels, HSS likes to rough slow and finish fast. By fast, I mean really fast with light cuts. For example, when I turn a 3/4" piece of 1144 on my little Sherline, I am running a finish cut at 2800 rpm. For your piece, I would try a fine cut at 15-1800 rpm and see what that does.
Carbide also likes speed. Finish depth of cut depends on the nose radius - what is yours? I would also try to increase speed for finish cuts on that piece; try 950-100 rpm and go up as needed. Your tool holder probably has a 5 degree positive rake and is normally used with the tool shank perpendicular to the work but try turning the tip toward the tailstock a little bit. This can really help the finish when taking light cuts at high speed.
