- Dec 20, 2012
- 9,408
Very straightforward. The process is the same except that the compound is turned 29.5 degrees toward the tailstock instead of the chuck and the lead screw must be run in reverse so that you're cutting from left to right. Same tool can be used as for right hand thread and it is oriented exactly the same way as for a right hand thread. It is best to create a thread relief so your tool has a place to start the cut. Should be simple for you to do.
