- Dec 20, 2012
- 9,408
Not bad, Richard, especially considering you're a new guy using a bench grinder. I'd bet money those tools will cut pretty well as they are.
The tool model you are calling a Turning tool is actually a knife tool used for facing. Both of your tools will work but the tool in the middle has better rake angles ground into it and I suspect it will cut better for you.
The tool you're calling a facing tool is actually a right hand turning tool or Square tool. Your tool on the far right will work better. The shape is nearly correct and the rake angles look pretty good. The center tool will also work but the rake angles are a bit shallow; it will cut but chip clearance may not be as good.
The threading tool looks pretty good. Did you match it up to a fishtail gauge? If not then do so; it needs to be exactly 60 degrees and you need a tiny flat at the front like the model.
Give the tools a try and see how they work for you. Don't forget to put a nose radius on your tools and ensure the radius follows the corner angle up front, from top to bottom. Hone the tools well and give them a try.
I highly recommend you reproduce the models in mild steel keystock and practice with keystock until you can duplicate the models very closely. Doing it with HSS can be challenging for new guys because it is much harder to grind. Keystock grinds easily and allows you to learn how to move your hands.
Oh, and just so you know, you did waaay better than I did in the beginning. You're off to a great start so hang in there and let us know how your tools work.
