- Dec 12, 2012
- 109
Hey guys,
I had a bit of time tonight to try the RH turning tool on a piece of Cleveland Mo-Max HSS that I had. I copied my copy of Mike's turning tool pretty much exactly, which took some time to accomplish considering my small grinder and Mo-Max is a tad harder than key stock... anyway, got it done and spent a decent amount of time honing, first by practicing on my key stock bit, then carefully on the HSS. Mike, I tried both honing techniques we discussed above and I felt I had better control doing it the way you suggested, basically piling up the burr (even though none really built up) on the cutting edge, then taking it off by honing the top.
The DMT plates I ordered arrived today and worked very well. (don't mind the shape of the back of the bit, I bought it used at a second hand store)
This is the new grind next to my previous attempt, using the South Bend manual as a rough guide. It worked with mixed results.
Please let me know if anything can be improved, particularly with the honing. I'm using a 6" grinding wheel so the hone is only really touching the edges.
Looking at this picture now, I kind of see a band of reflected light on the top edge. Is this what you're talking about trying to avoid, Mike?
I was almost going to stop there and go to bed, but I had to give it a try. The deeper cut is with very little lead angle (~10*) and the 1.25" piece of 6061T6 sticking out way too far. There are chatter marks on the surface as a result. Second cut (shiny one) is with a greater lead angle (as pictured) and the bar pulled into the chuck. Very very nice finish!!
Then I tried a piece of 1.5" mild steel. Same increased lead angle as before. Same impressive result on the surface finish. Then I put it to the test and successfully took less than .0005 off the diameter. Barely a hair of material came off the bar. Wow! Can't say I've ever done that before.
Maybe tomorrow I'll give the knife tool a try on some HSS. Gotta say I never thought I'd be putting so much time into grinding HSS, but I'm having a great time doing it now that I have some good direction!
Barry
Barry
