Better, Jeff. I can see some side and back rake now. The nose radius is too large and your edges are NOT sharp. If you look at the shot with the top view, you can see light reflecting off the cutting edge. That means the top is not flat all the way to the cutting edge. In 12L14, a good tool will produce almost a mirror finish. I would hone all three faces to get then dead flat and then the tool will cut as it should.
