- Dec 20, 2012
- 9,408
With that kind of tolerances, you need to bore it. A drill or end mill will not net you that kind of precision. Given that there is a hole in the bottom of the bore, you will not need to get the point of the bar to get to center and you can get away with a larger bar without running it into the wall of the bore. I suggest a 3/16" diameter Micro 100 solid carbide bar that can cut to your 1.5" depth. It will take micro-cuts to allow you the kind of precision you require.
