- Dec 18, 2019
- 7,674
I'm not sure if you got a lemon, or all the Amadeal mini-lathes are that way. Yours is an example of what can go wrong in this class machine. Believe it or not, we've heard of worse here...Okay, I'll weigh in for what it's worth.
I have a Weiss made Amadeal branded 7x14. I've had this lathe apart so many times over the past year to adjust, fettle and improve it and I'm still not done.
Partly because of this, and because most of the things I've turned have been close to the chuck and absolutely not requiring of any kind of precision, and because my 3J is a cheap San Ou, a full job of checking for bed twist, checking headstock alignment and tailstock alignment has been delayed. Honestly, I've had stuff to sort out on this thing ahead of that.
Turning an unintended taper over the 12 odd inches the average 7x14 has? Yeah, they'll do that straight out of the box. Sure, you probably can get that taper down to sensible respectable amounts if you spend a fair bit of time (and potentially money).
However, you'll also be deburring and smoothing out all the sliding surfaces (apart from the main bed ways probably), sorting out the lacklustre torque at low speeds (even with the newer brushless motor models), trying to get the saddle interface with the bed, the cross slide interface with the saddle, and the top slide interface with the cross slide, all tight enough to avoid play and loss of rigidity without making things so stiff you can't move anything smoothly, fixing the tailstock quill's shakiness, replacing the rack with one that isn't shaped like a banana, putting a cover on the apron so it doesn't get rammed with chips, getting the leadscrew well adjusted enough to power feed smoothly, finding a solution for the lack of a fine enough power feed, adding thrust bearings to all the handwheels, and maybe extending the cross slide travel by milling out the saddle.
Frankly, if you gave has an 8x16, I can't imagine why you would buy a 7x. I promise you, you will not make a Chinese 7x as good as the 8x16 in any way. The possible ceiling of quality of Chinese machines goes up the bigger they are.
Honestly mate, save your money and spend it on something else. There are decent enough reasons to buy a mini lathe but I don't think any of them apply to you.
If you want a challenge, go on AliExpress and seek out one of their little benchtop surface grinders and try to turn one of those into a usable machine. It'll add to the diversity of capabilities in your shop, and if you really can't make it work as a mini surface grinder, you can probably mod it to become quite a reasonable tool and cutter grinder.
I bought the nicest 7x16 that Little Machine Shop (LMS) offered at the time. Whether that means I got a higher quality lathe or not, I honestly don't know. Mine had really low TIR at the spindle, less than 0.0001". It had a taper, but I don't remember how much, since I was able to adjust it fairly low, with some help from this forum. Was everything adjusted correctly on my lathe, no. But it wasn't terrible. Mostly I just tightened gibs and things, per the included instructions. Honestly as a beginning user, I wasn't quite sure what I should touch, knowing that I could make it worse! As I got more confidence, I made minor adjustments. There were no major problems with my lathe. I made a differential screw tail stock horizontal adjuster. Made it easier for me to get the horizontal adjustment. It sure was fun to design. Also made a straddle knurler that mounted to a plinth that was hard mounted to the cross slide. That was a fun little tool to make. I use the knurler to this day, as I don't have an equivalent for my larger 10x22 lathe.
