- Aug 19, 2023
- 1,059
Check taper by measuring with a mike.
Would that be a 6' 225lb Mike with brown hair per chance?? LOL
I get what you mean, just having a little fun is all
Great idea!Check taper by measuring with a mike.
Excellent point.Check taper by measuring with a mike.
A smaller diameter on the right, or the tailstock end is not acceptable under any circumstance.Using a Mitutoyo 0.0001" resolution digit (not digital) mic, I'm at 0.7871" diameter on the left side of the turn, 0.7869" on the right side, over 2".
That's good enough for what I do .
Okay, it's possible I might have got the maths wrong here, and if I have, apologies, and if you're being ironic, well, use some emojiis, that's what they're there for.A smaller diameter on the right, or the tailstock end is not acceptable under any circumstance.
I don't understand. Please explain why the direction of taper matters.A smaller diameter on the right, or the tailstock end is not acceptable under any circumstance.
Fella was either doing what the kids used to call a 'weird flex'I don't understand. Please explain why the direction of taper matters.
