I think the vise not flat thing is a red herring.
I think it's not a flatness issue, either. I got the new indicator holder this morning and I checked to see if there was any rocking happening in any direction, and...
< drumroll > ...
there was.
The short version is this: when I mount the vise in the forward-most T-slot in the table, it's so front-heavy that it takes almost no pressure to accidentally tilt the vise towards the front of the mill and almost knock it off the table entirely unless you catch it at the last moment and strain your back...which, uh, totally didn't happen to me. When just sitting flat with no pressure from the mounting bolts, there's about .001" of rockery taking place, front to rear. And it's not that it's really rocking on a high spot; it just kind of feels... unstable.
If I move the vise towards the rear of the table - as if to mount it in the middle T-slot - all of that rocking motion vanishes instantly.
Hmmmm...
I don't think there's a high spot on the table and/or vise; rather, I think that when mounted in the forward-most T-slot, the center of mass of the vise is so far forward that it's really difficult to mount it solidly. Once that mass is sitting more solidly on the table, the instability vanishes.
When I look at the close up picture of the vise clamp bolt it looks like you've only got a corner on the square head of the bolt under the T of the table slot.
You are correct; it's not a great mounting method. I haven't had a correctly-sized set of T-slot bolts and nuts, so I was hoping these would work...and I don't think they're really doing so. As you pointed out, there's only a small amount of the bolt head catching and holding.
I think that there's not enough friction with just that corner of the bolt and that's why it is able to move on you. I think that if you used proper T nuts it would alleviate your issue.
I have a set on order as of this morning, sized 11/16" to fit the table slots, and with 1/2-13" threads. Hopefully they will help to solve the problem, but I also need to figure out how to keep the bolts from skewing sideways when I tighten them. At current, they'll move well over 1/8" when I try to tighten them down. I think the washers have a lot to do with this; the nuts are grabbing the top surface of the washer while the bottom surface is sliding around on the vise, and that just ends up eventually shoving the vise around on the table.
One other point. From your pictures it looks like you're using the moving jaw of your vise to indicate off of. I was taught that it was proper to use the non moving vise jaw to run the indicator across.
I agree. I need to adjust the contact on the indicator to better index the inside surface of the fixed jaw, but I'm not sure exactly how to do that, so I've been looking for a manual... unsuccessfully. So, I think I'm just going to have to figure out that adjustment without the manual, because I can't really get a good measurement this way.
