- Dec 21, 2018
- 2,075
The contact arm can just be pushed back with you fingers.I need to adjust the contact on the indicator to better index the inside surface of the fixed jaw, but I'm not sure exactly how to do that,
Maybe, but I doubt it. Easy to find out, do some tests.Also, you know what would probably help? Locking the Y axis when I do this, is what.
You will find that the needle bobbles as it slides along the jaw face even though the face feels smooth. Ignore it.
No idea if I tram correctly or not... But, I'll get the vice snugged pretty tight on one side. Locate the indicator arm close to the opposite side, start the X feed running slow. Use a mallet to tap the vice as the indicator traces across the jaw. By the time it reaches the opposite side you will be very close. One more pass to tweak the last bit out.
Always take your readings with the indicator moving in the same direction. Doesn't matter which. The friction on the tip will affect readings. When you are ready for the final check do it by moving the Y axis in & out to avoid any errors from the twisting action on the indicator.
Is it worth the time to do that?? If you think you can maintain 10ths Maybe.
There are an awful lot of points of potential movement on an inexpensive setup that may negativize the usefulness of a lot of tail chasing.
Best thing is to design for tolerances. There is no such thing as "perfect!"
0.0001" = tenths! A tenth of a thousandth!Tenths of an inch?
Me too, It just might not be the tenths I wanted.But for seriously: I can do tenths of an inch.
