- Dec 21, 2018
- 2,068
Look @ the bottom of your vice. I suspect it already has accurately machined slots & tapped holes to hold the keys. (I think I can see the end of one near the handle.) The easy way to get a very accurate measurement of the vice and table slots is with your gage blocks. You will likely need to make the keys stepped to fit both the vice & the mill table. Make them as one long piece, drill & counter bore for the retaining screws. Do a slight chamfer all around so they easily align with the slots. (the slots in the vice may not be perfectly square cornered!) Cut in to two pieces. If they are a bit tight use an abrasive/diamond stone to make them fit.That's smart. I think I can envision it, but shoot me a picture of it if you get a chance.
About the bottom of your vice. First look see if there are any dings producing high spots. If you have a surface plate, blue it up and gently set the vice on. Give it just a bit of a twist and lift straight up. High spots will have the blue transfer. Ideally you would do the same to the bed side after removing the jaws.
I'm guessing you don't have a surface grinder. That would be the best way to true the vice surfaces parallel. But not all is lost. There are labor intensive, back woods ways to get there. The method you chose will be based on how hard the surfaces are. Silicon carbide wet/dry paper wet it so the surface tension will hold it flat on your surface plate. Rub then turn the vice until it shows a mostly even pattern. The top gets the same treatment but checking to be sure it is parallel to the bottom. Discouraging note: It will be a lot of work if there is much deviation and you need a really good reference surface (Surface plate.) An easy out would be to just grind down the high spots with a coarse diamond hone in a tub of water. But it doesn't necessarily make the top & bottom parallel.
And last, put a limit on how much time you are willing to put into it. Live with what it is and get some use/ practice out of the mill. When you become rich and famous buy a new Kurt ($600+!!!)
