- Jan 31, 2016
- 13,206
The extended end looks like it didn't get broken . The broken one looks like a standard end support which should be available . I think the issue is the stripped nut and maybe the middle casting . I learned my lesson back in 86 moving equipment on dollies and went out and got a dock plate for the trailer . Yank it up with the winch and pull it down with the tractor . Machines slide easily on any hard surface . Not sure what the Leblond 20 x 120 weighed in at but the Kubota moved it around quite easily . You can roll machines around on pipes easily also , no need for a tractor . An 8' Johnson bar will move just about anything a hobby shop would need also . I can't tell you how many large machines we've moved over the years but it's been quite a few . I don't put anything on dollies after my incident .
