- Nov 14, 2016
- 3,289
I too looked at all the specs of both, And there are a bunch of videos about both on the net as well... I'm thinking going with a bare PM-932M as opposed to the VS one... is it really that big a plus to go with the VS over the Gearhead..?
Variable speed is nice but I don't think a huge thing. I have lathes that use both, variable is handy, but I don't find changing belts a big hassle. Variable speed on a lathe can be nice turning large diameter piece where bumping the speed up / down can give you a better finish, have not found it necessary when milling since the cutter turns instead of the work piece.
My Clausing is a belt change machine but it is set up with a 3 phase motor and VFD which gives it variable speed.
$900 cheaper I can see the appeal and it just moving levers / knobs seems much easier than belts. I've not used a gearhead, but understand they are noisier which could matter, but $900 buys a lot of I don't mind.
On the other hand as a forever machine $900 pretty quickly becomes a trivial amount divided over time, but regretting not splurging will always be there.
Definately worth some research on the M VS V from people with first hand knowledge.
The PM people seem to be very helpful and could probably help you here.
