After installing angular contact spindle bearings in my HF 7x10 (now a 7x16) and letting it settle in for a couple months or so, I felt the bearings needed a bit more preload which I did yesterday. Indicated off the inside of the MT3 taper, it's back to 0.0002" TIR using a Mitutoyo DTI so all is good.
I realize that 0.0002" TIR at the spindle is unlikely to hold up once a chuck is installed either on, or inside of said spindle. I have a Z Center Live ER20 collet chuck that may well be a unicorn; it reliably turns 0.0002" TIR mounted in the lathe spindle, indicated off the inside collet seat.
Lets say I add a collet which itself has 0.0002" TIR, in a perfect world should I expect the materialized runout of a turned piece to be 0.0002" or 0.0004"?
Somewhere I read that a lathe cannot turn a piece with less runout than it's spindle, I'm wondering if the correct answer is a lathe cannot turn a piece with less runout than the materialized, stacked runout of the spindle and the workholding assemblies?
