Hey Guys
For most of you that have non gear head machines, you might want to have a look in the end gear train. Many times there is usable tooth counts on the gears.
I used to use the end gears on my old 12X37 lathe for many dividing tasks. On my 41 Sidney, its a gear head machine, and I dont really have that option any longer. The only way for me on this lathe, is idexing either from the chucks adapter plate, or using the expanding spindle arbour as in the pics.
The plunger assembly can be done in such a way, that it could engage the tip of the gear, and also the root of the gear to further expand dividing capabilitys. My old 12X37 had the detent set up mounted behind the end gearing cover, and to use it was quick and easy. Open the cover door, loosen one bolt to ajust position, and lock in the starting point.
Just thought Id mention this, because many dont realize that the gears in the LH end train, many times have all thats needed to do simple dividing in the lathe, The user just needs to find a crafty way of holding these positions.
