- Jun 5, 2023
- 108
I would spend the $10 and get the next size larger. SST 6" More accurate, and a 1" travel vs the .25 on the smaller one and better resolution....
If you are looking for gauges to tram your mill I would suggest https://www.amazon.com/SST-Mini-Lat...hvlocphy=&hvtargid=pla-4583451676256931&psc=1 ...
Yes, @tim81 you are going to spend a lot of coin on tooling. Vice(s) cutters, collets, adapters, clamps, bore gauges, micrometers,...If you are going the cheap route with Chi-com tools and what not, make sure you verify the return policy, and check everything out thoroughly when you get it, primarily runout with anything that is going to be mounted to the quill or a quill collet.
I have a 6" vise that had .012 in Z across the base between jaws and .004 in Z at full open. I milled the base flat with the fixed jaw as the refrence, then a .001 skim off the top between jaws to get it usable for my needs. Still has a fair bit of lift when I clamp down but I can get around that.
