I need some advise on the 55.
I'm replacing the entire exhaust system front to back and changing the rear cross member to make it easier to route the pipes and found that when the new mounts were welded in the engine and trans are not installed inline with the center line of the car, back of trans is off 1" to the passenger side, trans looks too low by about 2", and the engine/trans is tilted to the right. I was considering pulling the engine/trans and putting in new engine frame mounts, but that would snowball on me. I wouldn't be able to resist cleaning and painting the engine bay.
So for now I can pull the back of the trans to the left, and can raise the back of the trans up and leave the tilt for now. I've been researching setting the angles and got the frame at almost perfectly level and I set the engine to zero deg at the carb base using my machinist level and was told that's wrong. From what I read the carb base is at -3.5 deg so the fuel would be level and evenly distributed. I found a tremec transmission app for my phone to set the anglesand it totally sucks. It has a real time readout and I adjust the engine trans to -3.5 deg, drive shaft says 2.8, rear axle is 2. Then I hit calculate and it says I'm out of spec with the trans at 7.5 deg. Waste of time to try using it.
Has anyone went through this and has some advise on how to go about this?
