- Nov 28, 2016
- 2,784
I was just thinking about this... just trying to visualize the angles, if the engine is at 3.6 down, and the pinion is at 2.4 up (going front-to-rear), BUT the shaft is only at 1.7 down, if you tip the axle up 6 to make it 3.6 down, your operating angles may be too much... the pinion may be higher than the transmission yoke... depending on how long the driveshaft is...
Have you installed the 9" rear axle yet?
-Bear
-Bear
