- Dec 18, 2019
- 7,196
Screws that have to be drilled out are the devil. That includes mangled Phillips head, and one way screws. They are a pain in the neck to deal with.
I have a Dremel as well. But I've busted more than my share of cutting discs. I'm acutely aware of what flying stuff can do to your face. To your point, a Dremel works as long as you have and can maintain a good position. Sometimes it's the only solution. If the steel is low grade, and over torqued, I find the fastener won't come out anyways and I still have to drill off the head. We have all experienced stubborn fasteners.Thats why I like the fact I own a dremel, cutting discs and thin tip grinding burrs/bits (amongst many other bits for the thing!).
Easy enough to make a groove to get a screwdriver into
not to mention "3 square" (which is 12 point to everyone else!!)
I got to experience a devil fastener just today. Rusted Phillips head screw, the indent was filled with solidified rust. Tried scraping it out, but not enough to fully insert the bit. The head started to strip. Out came the drill and drilled off the head. Replaced it with a stainless SHCS, because that is what I had. Of course, this all transpired outdoors in the blazing sun 93F with a dew point of 69F (better than this morning when it was 77F). My shirt was soaked from sweat. All the while, I was thinking about what I wrote this morning!Thats why I like the fact I own a dremel, cutting discs and thin tip grinding burrs/bits (amongst many other bits for the thing!).
This is most likely what it is, Reed and Prince used to be included in a good set of bits, I imagine R&P is obsolete by now.Reed & Prince.......
The Reed and Prince company name doesn't apply any more, it's "Frearson" now; good woodenThis is most likely what it is, Reed and Prince used to be included in a good set of bits, I imagine R&P is obsolete by now.
