How Would You Do This
Rick_B
H-M Platinum Supporter
Dec 10, 2011
485
I'm working on a table insert for an oscillating spindle sander. Material is mild steel - the basic shape was done on a water jet. I have faced off the surface to get the required thickness. Now I need to waste out material on the back side to leave a 3/8 wide rim.
Don't worry about the sloped surface in the center or the little plugs/protrusions. I'm not sure how to waste out the material from the edge of the rim to the center oval cut out - its roughly 3/32 that I need to remove. I'm using a 4 jaw chuck with the jaws reversed to hold it. Is what I am trying to do simply a facing cut? How do I achieve that nice square shoulder?
Thanks
Rick
Can you chuck it up internally on the ridge of the outer rim? That would allow a facing cut. A mag chuck would let you do it on the mill, or you could bore a stepped fixture plate with a sized circular relief and mill it that way.
My spindle sander has plastic inserts for thr different spindles(; I know you already save $$ invested in this part, but 3D printing would seem to be the best solution.
I currently have the jaws reversed and am holding the work piece on the OD. The wor piece is shimmed above the jaw surface and I used a facing cut to get down to the right thickness. I could use a facing cut to generate the relief but I'm not sure how to orient the tool to get the shoulder cut
Rick
I'm looking to stay original if I can. If I was going to deviate I would probably try wood
Rick
Rick
If you're going to face cut the material out, on the lathe in a 4 jaw, you could cut the shoulder with a boring bar.?.?.?
I ended up just facing out close to the rim and finishing up with a boring bar
You'll notice a variation in the rim width - that is a result of not checking run out when I put the piece back in the chuck. I could correct that but that width is not a critical element.
Now I need to figure out how to put the sloped surface on the oval section. I believe the only option is hand work as /Wally suggested. Wally you said you used a grinder - like a 4-1/2 hand held grinder? I put some bluing on it so I could scribe the 1/4" or so depth of the slope.
Rick
