On the contrary, the radial misalignment is what causes the pullout. As an example , if the misalignment is .05" towards the front, the rod will be twisted in the chuck towards the front which causes the end of the rod facing the touching the chuck face to lift slightly. As the spindle rotates, the end of the stock will be precessing, lifting a little more with each revolution until it eventually works its way out of the chuck jaws.
