Your steady rest is not concentric with the chuck, it is wobbling it back and forth and drawing it out as it rotates. I’ve had that happen to me before.
Do what rwm posted above, that should solve your problem. You might need to turn a section of the delrin where the steady will run to make sure it is round, if the delrin is oval for example, it might cause the same issue.
