- Oct 17, 2023
- 39
I have had good success with the Multifix style tool posts from PeWeTools https://pewetools.de/en/I got my Hobbymat MD65 a few months ago, spent some good hours in the workshop and lots of petroleum and oil cleaning it up and adjusting it, and it's now running very well. I'm a turning-beginner, I learnt to use a lathe 30 years ago in university, now finally now has my own and is trying to learn the basics.
I'm as well looking for a quick change tool post but a thing is puzzling me. I can't work out how any available posts actually fit on the machine with the tool height correctly aligned. I cannot get 10x10 mm insert-tools to align on the lathe sitting sit flat on the top slide under the inverted top-hat tool post, so how can a quick change tool posts that bolt on the top slide in the same location, fitting tool holders that obviously wrap around the tools to hold them align?
None of them seem wide enough to actually suspend the tool off the side of the slide, and few seem designed to do so.
I've seen some youtube videos of people fitting different tool posts to their mini lathes, and some even mill or scrape off material from their top slide. I'm not going to do that on my original 1981 Hobbymat, and by the way, it wouldn't work, as I'd have to remove so much that the slide would be destroyed.
I'd really appreciate if someone could post a picture of their toolpost on their Hobbymat. I've attached a photo of how badly a 10x10 insert-tool holder fit on my lathe.
This is my first post. This seems a very serious forum. I hope you guys will bear with my silly question
I have fitted these to all of my EMCO manual lathes which are a Unimat 3, Compact 5 and Compact 8.
I used AAA size posts on the Unimat 3 and Compact 5 and AA size on the Compact 8, both the Unimat 3 and Compact 8 needed minor modifications to the top slide to get the correct tool height.
I hope this helps you a little and welcome to the forum.
