- May 3, 2017
- 2,038
You're a genius.I've probably said this too many times but I have little space. No dedicated space for lots of things so I put them away when not in use. Built a stand for the belt sander using a bench grinder stand & mobile base. For the past year it's been sitting on a little table (what the drill press is sitting on in the pics). Now I just need to figure out where it's parking space is going to be.
View attachment 335343View attachment 335344View attachment 335345
Came with a hook for the power cord which was unexpected. Gave me an idea to maybe add more hooks for my extra belts. Not sure yet.
WIP pics:
See, no room! Had to roll the bandsaw outside. You'd laugh if you saw how I got the 10ft square tubing home.
This plate was too large to cut in my bandsaw in the horizontal postion unless I made multiple smaller cuts. Didn't want to waste material like that so I cut with the angle grinder then made the final clean up cuts with the bandsaw.
View attachment 335349View attachment 335365View attachment 335366View attachment 335363View attachment 335350View attachment 335372
Absolute widest my bandsaw can fit between the jaws. Fixed jaw moved to the outer mounting position.
Cookie cutters are great for marking radii that aren't critical. My radius gage set only goes up to 1/2". Not my idea but I thought it was a great idea.
View attachment 335352View attachment 335354View attachment 335368
Had to notch the mounting plate.
View attachment 335355View attachment 335356
Delrin stand offs.View attachment 335357View attachment 335359
Needed to remove the disc side to access one of the mounting holes. Sure I could have just put the nuts on top instead of on the bottom but it looks much cleaner this way.View attachment 335360View attachment 335361View attachment 335362
Thanks for looking!
