- Jul 6, 2022
- 533
Good info. Thanks.Bid difference between a gear box lathe and a gear head mill going WHAAAAAAAAAAA at 90+ decibels at full speed. Also 6 speeds is not enough and a top speed of 1600 is on the low side even for a 6 speed gear head mill. They are great drill and tap machines. Decent for steel, stainless. Just not fast enough to be good mills for aluminum imo. You can machine it but it's going to be quite slow.
Best mill in this category available today imo is the PM 940V. Extended Y travel, 5000 rpm spindle for starters. When you are considering Y travel also factor in vise positioning, column interference and whether you can even use the entire smaller Y travel most other mills offer.
I don’t think they have the equivalent of the PM 940V in the UK. If they do, it’s more than likely above my price range.
