- Apr 29, 2024
- 4
Yep, It does have have a one shot.Does it have a one shot, because that'd answer the oiling question.
That's a good point about using the mechanical drive. I do have it set up on a VFD but will default to using the mechanical adjustment. Personally, I find it more enjoyable to use that way anyway.Decreases the chance of the Reeves drive from freezing up, and also the belt to take a set. I often recommend to people using a VFD in combination with a Reeves drive to use the mechanical drive for speed adjustment as opposed to the VFD, this gives you the mechanical advantage of the drive and decreases the wear at one point. I also recall somewhere that at the end of the day when you are done using the mill, to bring the mechanical speed adjust to the low speed position. I do not see that the spindle lubrication should be an issue, nor would one need to exercise other parts of the machine on a daily bases. The Lagun are very nice mills, but the Reeves drive can be expensive to repair. As a hobbyist I wouldn't worry about needing to exercise it daily, but probably once a week to prevent anything from freezing up and the belt to take a set.
I figured either do something like this, or park it at the lowest speed like mksj mentioned. The middle would cause both pulleys to "pinch" the belt evenly, where as the lowest setting would have the least tension on the belt, but uneven pulleys. All in all it sounds like I don't need to overthink it to much and that as long as I cycle it through from time to time I should be fine for a hobbyist. Thanks!I'm thinking that it would be a good thing to "park" the Reeves drive somewhere near the center of its travel to reduce the tendency of the belt taking a set by having it bent to a minimum radius at the extremes of travel.
