- Feb 25, 2021
- 3,271
Either you're lucky or I'm not. And we're both using the same make saws, although I burned up my MS290 a few years ago after 15 years, cleaning up after a hurricane in coastal Georgia. Actually never had gas-related problems with the saws but I've had to replace the carbs on Stihl leaf blowers and trimmers though from gummed up carbs. A thorough disassembly and cleaning of the carb may have done the trick but that was pre-retirement.I have run 10% ethanol gas in my Stihl MS290 for more than ten years with no problems with either starting or running. I run the saw for two days each Summer, cutting the year's supply of firewood and then only a couple of times during the year for yard work or windfall cleanup. I don't bother about running the saw dry or adding stabilizer.
Next you'll tell me you've never had problems with algae in diesel fuel either!
