I build a fly cutter and made a cutter for it but every time I test it the cutter just gets eaten by the material. I made the fly cutter head out of 2 1/2" 1045 mystery metal I got from a local supplier. It is one piece and is made in the standard way, I didn't do anything clever or weird so I doubt that is the issue.
I ground the cutter with ~10-12 deg of relief and a slight radius on the cutting edge following several guides online. I have tested it on some 1 x 1 cold rolled 1018 but it always chews through the tip in the first fraction of an inch of the workpeice. I had always read that fly cutters were easy but this one is anything but. Does anyone have any Ideas?
This view let you see the chewed up tip (that angle on the end was not there when I started):
