Five Cylinder Radial With Ohc
Welcome back, Brian!!
Did you miss the project while on "holiday?"
Bill W.
Hi Bill
Dropping the project for a while has been rewarding, being on top of the problems all the time leads to overthinking some of them .
some perceived problems have simply disappeared after the rest.
Strangely I did not miss the shop but I am glad to be back. I think I missed H M and all of you more.
Brian.
The parts for this job are a 1mm drill and a 1 mm end mill plus a length of 1mm pivot steel.
The cross holes in the shaft where drilled first.
Then the slots in the pulley's
Cross pin cut to length.
And the shaft's assembled.
I am now waiting on the delivery of an ER 40 collet chuck so I can make the remaining camshaft pulleys
Brian..
nice job Brian, This was one of the Area's that I was interested in how you would drive the valves. Because it is a radial engine.
At last I can fit the rear cover with all the works inside apart from the oil seals that separate the wet gear case from the dry belt casing
the outer bearings will be covered with caps that will set the end float for the shaft's ,these in turn will be retained by the pressure and scavenge oil
pumps that will be co axial to keep the size down.
The ER 40 chuck has arrived so now I can continue with the camshaft pulleys and then the belt tensioners.
Brian.
With the ER40 collet I can now hold the blank material for the pulleys better so I am ready to go.
Part off the bar to length
Turn down the boss
Cut the inner flanges
Then the outer flange come timing disk.
Drill and tap the holes for the pinch screws.
Assemble ready for fitting.
Brian.
Continuing with the tensioner I have now tapped the thread for the pulley retaining screw and threaded the fixing shaft . Photos of it in place ,just needs the shaft cut to length and a Nylock nut.
4 More to do Brian.
