B
Bill Gruby
Forum Guest
Register Today
Stack the blanks and cut them all at once Charles. It's all downhill after the first one.
"Billy G"
"Billy G"
If you stack them, then you need to be careful about cutting tapers that can add up to out of tolerance conditions.Stack the blanks and cut them all at once Charles. It's all downhill after the first one.
"Billy G"
It doesn’t matter if done on a lathe or mill. What matters is the machines datum center line holding the arbor and blank(s) must be true to the cutters travel. And I do stack/sandwich blanks on each end of the project being made. When you do this, it helps reduce the possibility of burrs on the project.Are you using a mill or lathe to cut them? The taper could happen in the lathe when stacked but it's doubtful in the mill.
"Billy G"
