Five Cylinder Radial With Ohc
Beautiful! What do you expect for HP, RPM, other parameters?
Robert
:applause: I have run out of superlatives.
I am in awe of this standard of work.
Hi Robert and all.
I have not given a lot of thought to It's output, firstly I just want to see it run. I don't like screamers, so I am planing to run at 3000 rpm so it sounds right.
Then If I can get enough power I am planing to make an RC aircraft based loosely on the Spirit of St Louis slow with lots of lift likely to be about 11 Ft span.
All pie in the sky Until it runs ????
And thanks to you all for following along
Brian..
It this were my project, I'd be grinning right now like a kid a Christmas! :D
All I can say is WOW Brian. At this rate what are you planning for the winter.
Greg
Beautiful piece of work right there! Thanks for sharing the ride Brian.
That is a lot of chips. You should be saving them to melt down and make something else with them.
That looks great, Will you be coating the outside to keep it looking that way or will you let it get a natural patina
Of course you made it weigh less, how else is it ever going to fly. Beautiful work Brian, keep up the posting please.
Greg
If I made that work of art I could not bring myself to put it on the front end of a flying machine. How about a pusher prop plane! Or an airboat?
R
