B
BRIAN
Forum Guest
Register Today
Hi Ken.
I ordered the blank thick,because I was worried about holding it and thought that I may have to drill into it.,we will see.
When I have it on the face plate it will be reduced to 16mm thick then it will form part of the jig to machine the case. After that it will be reduced to 10mm. and the seating's for the crank bearing also the bearings and pockets for the intermediate gears, On the inside it will be relived to reduce weight.
It also allows the crank to be fitted.
You can get an idea of it's importance on this ghosted drawing,
This may take a while.
Brian.
Brian.
