B
BRIAN
Forum Guest
Register Today
AT last positive news the assembly of the cages went smoothly , and I made three drill bushes to guide the drills when I open the ports in the cages, this gives me stages to inspect to see if the alignment is correct.
At this point I have decided that it would be wiser to continue work on these two heads just in case a design change is needed. so the (scrap) head will be used to test. followed by the first production head, only when I have a full working assembly will I continue with the other four.
I have done another slide video. but have made a mess of the titles for each slide I had it all OK but the upload swiped off all my work. However you can see it on my You Tube channel
( brian hogger ) I cant seem to get it to run from here.
The valve seats are perfect 45° .5 mm wide and concentric with the valve guide.
Brian.
Brian.
