- Dec 26, 2015
- 2,154
Which A.R.Warner insert are you using - TNMC or TPMC? Looks like tool chatter to me.UPDATE:
I got the lathe back into position, leveled and tried threading with some barrel drops that Bamban gave me. Overall, vastly improved. I tried threading with just the cross-slide and a new AR Warner HSS tool / bit. 16 TPI at 65 RPM. I fed at 0.003 for 2 passes then 0.002 for 11 passes then 0.001 with a spring pass for 10 passes. Still feel some coarseness in the threading. Close inspection of the result reveals some surface irregularity that I can't figure out.
