- Aug 3, 2017
- 2,419
A little more work today! One thing I DO need to do is find some sort of metal project box to go UNDER the machine that is of a good size (IIRC, 13-1/4" x 9", 2" high) to hold the power supply. If anyone has a good source of something like this, I'd be grateful if you can share!
Today was a bit of a "do what I can while I can", since the mill has a setup that is a pain to take down that I am waiting on something to finish up, so I don't really want to tear into it just yet, so I tried to stick to lathe work.
I started out by reaming and broaching the plastic gears:
The second thing I did, was decided I need the 'hob' holder adapter, its the MT2 adapter that goes in the hob spindle. First, I took a hunk of aluminum, drilled and reamed it for MT2. I used the drawbar to hold one of the MT2 blanks, centered it in my 4 jaw, then turned it down so the hob will fit:
The hob is quite a bit longer than the MT2 blank, so I made a washer + hob support in 1. This should keep the pressure from the bolt even:
I still need to cut a key in it, but thats project for another day
