- Aug 19, 2023
- 1,324
When you are just using the chuck, slide the tail stock off if you want more clearance.
At least give the 5C a try. Holding small, very short work is something an ER system can't do.
@Larry$
Wrong, ER32 can hold short work. You simply use a section the same diameter stock behind it so you do not distort the collet, there are also other ways to hold short work with ER32 if you use your head to work out the solution.
As for sliding the tailstock off, I generally do not do that for a vast number of reasons including the fact that the space the lathe is in, it is a pain in the a$$.
It seems the obvious solution is to buy a bigger lathe - to fit the chuck.
@Chipper5783
Talk about an inappropriate comment.
I then got an ER32 set which totally overlaps stock size so I can accurately grip anything from 1/16 to 13/16.
@epanzella
That is why I went ER32 from the very beginning with the "option" of adding ER50 later if I could justify the need for it.
I have ER32 collets from 0.5mm to 26mm with 0.5 increments in some places across the metric set as well as a set of imperial collets, so I have every combination I need for now. I also find the 0.5mm (197 thou') clamping range of ER collets more useful than the 3-5 thou' (approx 0.1mm) of the 5C system.
