I am deep into the process of putting a Clough42 ELS on my 1949 Myford ML7.
I am also looking for any help/guidance/juju that will make this thing work, else I will send it to the scrapheap in the sky and buy a Rocketronics outfit.
I am following exactly the process laid out by Clough42. I have a TI F280049C with a Clough42 booster board. I have an Omron E6B2-CWZ6C encoder and the hybrid servo motor specified by Clough42.
In putting this all together I treble checked continuity and crosstalk. I admit to being a klutz regarding soldering but all the connections are fine and work properly. I did manage to blow 2 of the Display boards (not connected to anything at the time) when I tried to desolder the 5-pin connector. I ended up with one of Clough42 display kits which look really nice -- if they worked.
Regarding the display, I found that I could solder the leads to the board as delivered, then bend the pins, suitably insulate everything and fit the whole thing into a slightly bigger box. No desoldering !!
The display lights up -- the opener with the Clough42 logo, then the ELS 1.1.02 version, then the left hand side shows 0, the right hand side works fine allowing me to set threads etc. The problem comes when I plug in the leads from the encoder into J12, the display dies just showing a live power LED. When connected, the 3.3v LED on the booster board turns off but the 5v remains lit.
OK says I, I must have screwed something up and blown a board. So I sequentially replaced the booster board and the encoder. No Go. Nothing changed so I bought a new TI board.
This sucker would not even boot no matter what I did. I tried CCS v9.0.1, v9.1.0, v10.1, v8.something -- nothing, and in between times I struggled with our friend Microsoft which released a new version of Win10, so I have gone through the issues of unsigned drivers. That is now behind me with signed drivers on Win10 v1903, but still the new board refuses to connect saying it cannot find XDS110.
Board settings are as I think Clough42 is now specifying -- S3 both at zero, S4 at 1, S9 at 1.
Does anybody have any ideas?
I think the whole concept is a great idea and will bring life to many old hunks of rusting lathes. Think about it, when you go looking for old lathes you often find the only things missing are the change gears, which are virtually impossible to replace. This project, if it worked, would fix that.
I should say that I am not *****ing about Clough42 as I think his videos are the very best on the web and he clearly makes an effort to do them well. In particular the sound management is very good and he enunciates his words well.
Does anybody have any ideas.
Thanks, Ian
