Great! Glad solution exists. Yeah 1900 rpm in bigger steppers is poking along a bit quick!I did a couple of cuts using the ELS. I successfully turned a length of 1" HR with a feed of .030"/rev. and .030" d.o.c. @ 588 rpm. If I did the math right, that amounted to 1.66 cu. in./min which is a fairly healthy stock removal rate. This amounts to a feed of almost 18 ipm and a stepper speed of 423 rpm. (I use a 2:1 gear box reduction) so my stepper rpm is twice my lead screw rpm.)
When I tried .030"/rev. and .050 d.o.c., it stalled the lathe and chipped the insert in the process.
Looking a no load ceiling, at 3 mm/rev, the stepper tracks but it fails at 3.5mm/rev. This corresponds to stepper speeds of 1667 and 1945 rpm, and 69 and 81 ipm, respectively.
With that, I am fairly convinced that the ELS will be able to handle my needs.
Max I achieved w mine, was about 1500 on the bench, so all good.
Am sure 1.66 ci would suit me too RJ, well done. 50 thou doc on smaller lathes is pretty vicious. Mine's a bit bigger, heavier, and wouldn't try that.I did a couple of cuts using the ELS. I successfully turned a length of 1" HR with a feed of .030"/rev. and .030" d.o.c. @ 588 rpm. If I did the math right, that amounted to 1.66 cu. in./min which is a fairly healthy stock removal rate. This amounts to a feed of almost 18 ipm and a stepper speed of 423 rpm. (I use a 2:1 gear box reduction) so my stepper rpm is twice my lead screw rpm.)
Looks like your tests show that your LS not being overloaded with reasonable cuts.
What was the Nm rating of your stepper again?
(Being lazy here).
So what happened re finding the right driver tuning software ( u had asked Briney eye).?
